QUESTIONS ON YOUR BENZ's I CAN TRY TO HELP!!
Old 03-24-2009, 11:31 AM
mditka86's Avatar
Mar,
Good luck with your new business. We need more MB specialists in the world!
I posted this question early but didn't receive a response so I'm hoping you can shed some light.
I have a 2000 E430 with a mysterious behavior. After a suspension alignment the steering wheel will be straight as the car tracks straight...everything fine....until I rotate the tires. The car will still track straight but the steering wheel is no longer perfectly level...currently slanted slightly to the right. No real problems but it drives me crazy as I'm always looking at it! This behavior has been consistent even through a new set of tires and different brand. Also the problem occurs whether I swap the tires front to back & right to left or simply front to back. What could be happening?????
Thanks, Matt
  #82
Old 03-25-2009, 12:52 PM
erchiestark's Avatar
Default Mercedes 500sel hood star
hi, i have a 1982 mercedes 500sel and was wondering if anyone could tell me if hood star part number A 210 880 01 86 will fit my car ? thanks
  #83
Old 03-27-2009, 12:11 PM
dabek10's Avatar
Hi, I have a 1999 mercedes e320 and gas is flooding and leaking from charcoal canister shutoff valve. There is also gas in charcoal canister filter. Wondering if you could tell me what could cause this and what parts i will need to replace. Thank you very much.
  #84
Old 03-31-2009, 07:09 PM
Palerider's Avatar
Default 87 300d Turbo
I was hoping for you help! Not sure if you are still answering questions.
I have an 87 300D Turbo with 126k miles, every thing is working great except the turbo is not producing boost to the engine. Any suggestions where to start troubleshooting? The recall on the turbo has been performed.
Not sure if there is a vacuum line, or something other then a complete turbo replacement.
I would greatly appreciate any suggestions.
  #85
Old 03-31-2009, 08:39 PM
craigxrx's Avatar
Default Runnin' warmer
I have a 1998 E320. Lately when I come to a stop and sit awhile, the temp gauge may climb from 80c to 90c. When I start driving, the temp goes back to 80c. Any suggestions??
  #86
Old 04-01-2009, 03:58 PM
mbzachs's Avatar
Hi Masterbenz! Thanks so much for giving everyone here your insight!!! Its greatly appreciated. HELP!!!!
My issue is this: I have a 2000 C230 Kompressor. When the engine is warm the crank time is very long. It cranks and cranks and cranks...and cranks and then finally turns over. When the car is cold there is no problem at all. I was told it is either a CAS or Fuel Pressure problem. I took the car to my local indy and they couldn’t replicate the problem. It only happens after the car sits warm for a while. Have you ever run into this?
Thanks!
  #87
Old 04-04-2009, 11:25 AM
strat804's Avatar
Default power windows out
Masterbenz, I just got this s320 and all power windows are not working. All other power options work. I can't locate a fuse for the windows but checked window lift? Is there a certain fuse for the windows or relay I should check for. Any help is much appreciated.
  #88
Old 04-04-2009, 01:31 PM
jimishadow's Avatar
Default alarm problem
can you tell me how to turn off or remove stock alarm in my new car.its a 1987 300sdl.thanx
  #89
Old 04-05-2009, 03:04 AM
mitodoch's Avatar
hi mar my c280 automatic will not engage top gear all other gears are fine any quick suggestions or is it a new box case thanks
  #90
Old 04-06-2009, 10:14 AM
Inkazak's Avatar
Default Dad's car
Hi, my dad died last month, and I am getting his old 60-something Mercedes. I do not know what year it is yet as I just found out I am getting it today.
I thought about taking it to a mechanic but I kind of want to work on it myself. It has my dad's sweat and heart in it, and I want to touch what he touched.
I know that it needs 2 ball joints on the front & it has plexiglass in the drivers side door instead of glass, I think it needs brakes on either front or back. The front seat needs to be replaced, because the springs have given up
So basically this is a project car. Should I work on this, or am I likely to make everything worse since I do not know a ton about cars.
BTW I am also located in Virgina, in Radford. Can you get parts for this car? Either new or used? Will only mercedes parts fit with this car or are there other options? I would very much appreciate your help. Thank you.
Quick Reply: QUESTIONS ON YOUR BENZ's I CAN TRY TO HELP!!
