need help please
Old Nov 30, 2007 | 03:24 PM
FLORIDAMUSCLE's Avatar
Default need help please
2000 s500 drivers side power stopped working,,,window switches,drivers seat adjustments.....any ideas? all fuses are checked and good..
mikeygold@yahoo.com
passenger side works fine....happened after windows were tinted? coincidence???
Old Nov 30, 2007 | 05:54 PM
NAZ's Avatar
NAZ
Default RE: need help please
WAS THE DOOR PANEL REMOVED OR ???IF NOT THAN I WOULD REMOVE BATTERY TERMINEL AND REFIT SEE WAT IT DOES, WEN REMOVIN AND REFITTING THE TERMINAL MAKE SURE KEYS ARE NOT ON THE IGNITION IF THE ARE THAN ITS A VERY VERY EXPENSIVE JOB, WAT IT DOES IT SURGES THE EIS..........
Old Nov 30, 2007 | 07:08 PM
chassis221's Avatar
if they took the door panel off it is very possible that a connection plug came unplugged in the door. called the DCM door control module has numerous electrical plugs.
MARIODRIVE
Nov 23, 2008 05:39 PM
lubee84
Feb 16, 2008 10:29 AM
sql123
Dec 1, 2007 12:11 AM
angeljade
Sep 17, 2005 01:37 AM
ezeneli
Apr 8, 2005 03:05 AM
