need help please
2000 s500 drivers side power stopped working,,,window switches,drivers seat adjustments.....any ideas? all fuses are checked and good..
mikeygold@yahoo.com passenger side works fine....happened after windows were tinted? coincidence??? |
RE: need help please
WAS THE DOOR PANEL REMOVED OR ???IF NOT THAN I WOULD REMOVE BATTERY TERMINEL AND REFIT SEE WAT IT DOES, WEN REMOVIN AND REFITTING THE TERMINAL MAKE SURE KEYS ARE NOT ON THE IGNITION IF THE ARE THAN ITS A VERY VERY EXPENSIVE JOB, WAT IT DOES IT SURGES THE EIS..........
if they took the door panel off it is very possible that a connection plug came unplugged in the door. called the DCM door control module has numerous electrical plugs.
