Help wanted please
Old Jan 25, 2009 | 03:44 PM
sid7777's Avatar
Default Help wanted please
Hi i have a s class w140 1996 the passenger side rear door will not open the
central locking cycle is working the **** on the door goes up when unlock
and goes down when you lock the door.The door will not open from the inside
or outside i have even tried pushing from the inside with some force but no
luck i have also locked,unlocked dooors with remote and key a good number of times just to make sure still no luck any help / advise will be greatly appreciated.
regards sid
Old Jan 25, 2009 | 04:16 PM
1sloturtle's Avatar
the internal door latching mechanism is broken most likely you will have to replace the door latch assembly if the door does not open from the outside and inside its the latch. if opens from outside grab handle but not inside release handle its possibly the release cable detached from latch mechanism , best to remove door panel have window rolled all the way up , check the release cable is not binding or jammed in unlock position.
Old Jan 26, 2009 | 05:29 AM
sid7777's Avatar
Default door not opening
Hi thanks for your advise i am sure that something is broken inside the door
would you know how to get the door panel off while the door is shut closed
sid
MARIODRIVE
Nov 23, 2008 05:39 PM
lubee84
Feb 16, 2008 10:29 AM
sql123
Dec 1, 2007 12:11 AM
ezeneli
Apr 8, 2005 03:05 AM
siddiqui2000
Feb 16, 2005 01:16 AM
