Remote locking
Old Mar 24, 2007 | 09:44 PM
gspeaking's Avatar
Default Remote locking
I have a 1997 E320 purhcased last summer with 56,300 mile. Other than a few repairs, i.e. both rear outer tail lights and tires I have had no problem. Shortly after getting the car the trunk remote lock stopped working. That didn't bother me much but now the drivers door remote doesn't work either. I replaced the batterys in the remote flip key with no positive results. Can anyone suggest a fix that might be a DIYS or do I have to go to the dealer>
Old Mar 25, 2007 | 05:10 AM
snanceki's Avatar
Default RE: Remote locking
Do the other doors and fuel flap work correctly on the remote?
If so you have a failed boot and door pneumatic lock mechanism.
If not then the pneumatic pump (called PSE) located in the boot has gone defective or alternatively the Remote/DAS (receives the signal from the remote) is not working.
Stuart
Old Nov 30, 2008 | 03:30 PM
planetobagirl's Avatar
If PSE is defective , what does that run to fix ? My gas cap door is locked and I cannot open it even when car is unlocked .
Old Nov 30, 2008 | 03:38 PM
Old Nov 30, 2008 | 08:35 PM
Peter Guenther's Avatar
The gas door can be released manually behind the liner, you could have a bad pump
Old Nov 30, 2008 | 11:06 PM
snanceki's Avatar
Not sure of USA pricing. Pure guess 200USD?
Its a plug in "black box" that contains a mix of mechanical (pump), electrical (relays) and electronic (logic sensing) components.
Stuart
1996slk230k
Sep 19, 2006 03:40 AM
fay3131
Feb 4, 2006 05:55 PM
sjp
Sep 17, 2005 08:27 PM
Kathypg
Dec 4, 2004 07:04 AM
rikblacketer
Jul 15, 2004 10:58 PM
