tint/remote locking question
Old Feb 3, 2006 | 07:02 PM
fay3131's Avatar
Default tint/remote locking question
A friend of mine has a newer model mercedes with the antenna for the keyless entry on the rear of the roof. They had the back window tinted, and afterwards the keyless entry only works sometimes. MB said the tint person must have gotten water inside the relay box located in teh back of the car in the headliner, they also said the whole window must be replaced. The tint won't pay to fix it unless MB puts it in writing that he is the cause. My question is this, if the tint guy really caused this problem by getting water in the box wouldn't it not work at all, instead of sometimes? Secondly, I know tint on the window can mess with radio reception, but what about keyless reception? Also if water was the cause why does MB want to replace not only the unit but the entire back window? I don't see why unless it affects the reception that the whole window needs to be replaced. Any input would be appreciated, he is thinking about getting a lawyer and going after them.
Thanks,
FA
Old Feb 3, 2006 | 07:21 PM
Lugnut's Avatar
Default RE: tint/remote locking question
When something becomes defective and no longer works as designed, it's difficult to predict exactly how it will work.
The service writers would, as a general rule, write down the reason for a repair. I've asked them to write something down specifically on the work order before to cover my ***. If they're saying it was the tint guys fault, then tell them to write that on the order. They should do it without a fuss.
As far as the window replacement, are they saying the entire window needs to be replaced because there's tint on it--that replacing only the relay won't do any good if the tint stays?
Old Feb 3, 2006 | 10:57 PM
fay3131's Avatar
The window thing is what confuses me so much. Why do they want to replace the whole thing? By the way they did refuse to write that on the service order. I don't know why because I am getting everything second hand. Hopefully I can find out some more information.
Thanks for your input so far.
FA
Old Feb 3, 2006 | 11:05 PM
sleepwalker's Avatar
which C-Class and what component is it?
[IMG]local://upfiles/1/C0EA3B0DDB614EEC848FFBD44176D58A.jpg[/IMG]
Old Feb 3, 2006 | 11:18 PM
fay3131's Avatar
it's a 2005 c 230, I think, and another dealership told them that the reception for the keyless is in the back windshield which is why they have to replace the whole thing. Is that correct?
Old Feb 3, 2006 | 11:37 PM
W203?
the one on the top inner part of the windshield is the antenna amplifier.
maybe he only got remote key and not keyless-go.
if he uses metallized window foil, then it will reduce the reception by 70% on AM, FM and TV by 10%, and 50% for range of radio remote control.
another problem:
if they cut the tint after installing it, then they must have cut also the antenna wire embedded on the glass. if they did, both the glass and the amplifier needs replacement.
Old Feb 4, 2006 | 05:55 PM
fay3131's Avatar
Thanks I appreciate your help, you da man
Jurrr
Nov 2, 2017 09:08 PM
caseyface
Apr 9, 2008 11:41 PM
carmotion
Nov 12, 2006 12:33 PM
Kathypg
Dec 4, 2004 07:04 AM
rikblacketer
Jul 15, 2004 10:58 PM
