Mercedes repair secrets
#161
Came from a friend of mine with this:
a) P0300;
b) P0301;
c) P0209.
Mercedes rules right?
And today i change the injectores but the car dosent work normally. All the codes are gone but came with a new one: P08... Gear box sensor.
By the way the car as a LPG conversion and on LPG works normally!
a) P0300;
b) P0301;
c) P0209.
#162
how to clear the scheduled maintenance msg on dash?
i have a 2004 c230 and i was wondering if u could hep me remove the scheduled maintenance reminder msg on the cluster. I also have a problem with my ashtray. It wont close on the left side. how could i fix these problems? any help will be greatly appreciated. thanks, Mike
#163
C300 2008 b Service reset
How do I reset the B service reminder?
Mike
Mike
#164
merc c180 1996
it suddenly cut out whilst driving along so then i called the AA and they come out and said it was the crank sensor. so i bought one of those and fitted it but still no joy, phoned the aa once again to come out and they checked the crank sensor and said that was ok. but its still not starting, the injectors are not switching, the fuel pump is not working and theres no spark from the plugs
ste
ste
#165
stegud -merc c180 1996
It looks like a electric thing. Have you cheked out the battery?? Or the onboard computer or even the contact key.
#166
2002 C230 Kompressor Sunroof failing
Hello,
Recently I discovered that my sunroof is stuck and whenever I try to open or close it I get an awful grinding sound. Currently the window is stuck OPEN about 2 to 3 inches and will not move. Considering I live in Oakland, CA it would be really great if I could get this figured out pronto. What would you recommend?
#167
Temp sensor on 06 C230
My temp on the instrument panel is off by a mile on outside air temp. Was wondering where the actual sensor is on the car so I can check it and see if it ok. thanks a bunch.
#168
hi.....
can you send me the manual repair for sunroof/moonroof w202 ?
the sunroof sometimes stuck!!!
my email : a_prakersa@yahoo.com
thanks
thanks
#169
Hi
How can I keep up the charge in my C Class battery when I leave it in garage and go away for 6 months? Please reply nicholasbroadley@aol.com - many thanks
#170
i left the keys to my C230 99 inside the trunk and i cant find a way to open it and i dont have a spare key how can you help me
