Mercedes repair secrets
#131
Hi I have a 1992 300e 3.0 witha electrical draw I took the radio out ever since the alarm has been causing this draw I think. I have to keep charging the battery any advice
#132
the power antenna is a commmon item that causes draw in those cars
#133
hi sir, thank you very much for your suggestions. the bearing is still good , its was check by a certified mechanic. what do you mean by sub frame and where can i find it. and what do you mean check the strut, what could go wrong with it and how would i know if it is good. what is your location, sir??
#134
#135
outside west of philadelphia is where i am.
#136
I have to replace the front and rear brake pads on a 2007 e350, I have seen posts which call for the doors to remain locked during the procedure. I was wondering if you had detailed instructions for this and any reccomendations on the type of replacement to use? Thanks for your help.
Mark
Mark
#137
dont need to be locked ...just dont operate anything when doing the brakes.
#138
subframe is where all the suspension components are attached to. not the actual frame. its aluminum and 4 large torx bolts hold it to the main frame.
#139
95 C280...while driving ,you can feel the engine surging and the check engine light "on"..not a big surge, but you can feel it..and now have a strong raw fuel odor..it's my brothers car..I cleaned the throttle plate as it looked pretty dirty..disconnected the battery to reset the codes..ran fine for 45 minutes..now the check engine light is back along with the surging..any help would be greatly appreciated..!!!
#140
hello, can you please help me my key fob does not work. The battery was detached for a few days at a garage. Since it has not worked. I had it checked and they say its needs a new brain. Oil leaking into it. Can you help?
