C320 Ignition Switch - Starter Stays Engaged
Old Aug 7, 2012 | 10:17 PM
GoesTo11's Avatar
Default C320 Ignition Switch - Starter Stays Engaged
My daughter's 2002 C320 (92K miles) is getting the PO341 Camshaft Sensor error. No performance problems, but sometimes problems starting (which research [here] has shown is probably related to the CS sensor and I will troubleshoot/replace this week.) My concern is that when the engine does not start, the starter stays engaged until you turn the ignition switch all the way back to the off position. That is, even though the key is released to the on position, the starter is still engaged, spinning the engine as if the key is being held in the starting position. When the engine does start, the starter disengages with seemingly no problems. Any ideas on what could be causing this? Thanks.
Old Aug 8, 2012 | 03:35 PM
chassis221's Avatar
This is normal for your car. most Benzes have the TIPSTART feature. not to worry. it will stop on its own after a few seconds. it has nothing to do wth your issue.
Old Aug 9, 2012 | 08:02 AM
GoesTo11's Avatar
Thank you very much for reply. I thought that might be the case and since it has always started immediately in the past, that I just had not experienced it. Again, thank you for taking the time to reply.
Old Sep 23, 2012 | 07:36 PM
dakudaman's Avatar
My 2002 clk430 is acting wierd all of a sudden. The starter engages but it wont start then 5 hours later no problems. The other day it started but wouldn't go into gear untill I shifted r-d and back again. I feel today may have been an anti-theft thing, maybe I am wrong, as far as the not going into gear no idea. Any input??? PLEASE!!
autobuff
Aug 24, 2014 02:44 AM
KleanW123
Nov 17, 2011 09:37 PM
hally
Dec 29, 2008 04:21 AM
chiefv
Sep 21, 2007 11:14 PM
leximus
Jun 8, 2006 11:32 PM
