Other Post discussion on all other models not listed above here.
Front Brakes Engaged When Driving...88 300SEL
Old 06-04-2006, 01:58 AM
leximus's Avatar
Default Front Brakes Engaged When Driving...88 300SEL
It seems like the front brakes are engaged when my wife's car travels 15 or twenty minutes or so in speeds in excess of 30 mph. The front end vibrates so badly, the tires smell like they're burning and smoking. We had the front tires replaced, still the same. Had front end alignment, still the same. Ball joints replaced, still the same. Then we thought it was the calipers freezing up, so we changed to new calipers, rotors and brakes, and still the same. :cry:
What can be causing this? It can't be the emergency brake because it is rear wheel drive. Anyone ever have this problem? :? I need some major help after spending 1200.
Thanks in advance for your input.
Old 06-05-2006, 05:39 PM
BlackWolf's Avatar
Default RE: Front Brakes Engaged When Driving...88 300SEL
Did the ABS light come on?
And while changing all them components, did they check to see that nothing bent was contacting the front rotors?
Old 06-06-2006, 12:15 AM
leximus's Avatar
No, tha ABS light isn't or hasn't come on. There is nothing bent either....Any other ideas?
Old 06-07-2006, 04:22 PM
BlackWolf's Avatar
hmm you got me there without seeing the car in person, but try emailing Sleepwalker. He probably could tell you exactly what's wrong. Sorry I couldn't help much, but it might be a drive train problem, something is starting to lock up it sounds.
Old 06-08-2006, 11:32 PM
Sounds as though you may have some bad Brake Hoses or a proportioning valve acting up in the ABS if equipped . The vibration is and odity unless the brakes are grabbing enough as you say to cause it.
GoesTo11
09-23-2012 07:36 PM
tonybh
04-19-2010 07:03 PM
rohitsagar
09-07-2009 08:43 AM
chiefv
09-21-2007 11:14 PM
rpmgeorge
10-21-2004 01:25 PM
Quick Reply: Front Brakes Engaged When Driving...88 300SEL
