Mercedes AMG Class All AMG Models.
supercharger always engaged
Old Sep 18, 2007 | 05:15 PM
chiefv's Avatar
Default supercharger always engaged
The supercharger in my slk32 is engaged even at idle. Is this normal? I don't have any fault indication whatsoever and still has the power. Should I be concerned? Does anybody had the same problem?
Old Sep 19, 2007 | 03:03 PM
fesgali's Avatar
Default RE: supercharger always engaged
A supercharger runs off of a pulley that usually is run off the crank pulley. By this I mean that when the vehicle is on the supercharger will also be working. I'm no MB tech speacialist but I'd say that there is nothing wrong.
If your comparing a supercharger and turbocharger you gotta know how each one of them work before trying to find a problem.
Old Sep 20, 2007 | 12:02 AM
chiefv's Avatar
Thanks for the advise. You're right!!! The supercharger is fine. I concluded that the supercharger was engaged even at idle initially because I can see the clutch and supercharger spinning at idle. I disconnected the electrical connection to the clutch and drove the slk32 around and without the superchargerengaging, the drive really sucks.Doing this confirmed that the supercharger really is not engaged at idle.
Old Sep 21, 2007 | 11:14 PM
chiromikey's Avatar
ORIGINAL: fesgali
unlike the typical s/c car, amg's s/c has a clutch driven pulley that only engages during higher rpms or when the ecu determines the extra power is wanted or required.
GoesTo11
Sep 23, 2012 07:36 PM
leximus
Jun 8, 2006 11:32 PM
KenF
Dec 4, 2005 03:55 AM
fly_major_fly
Nov 25, 2005 06:37 AM
snikroc
Nov 13, 2005 07:39 PM
