2002 C230 Panoramic Roof Problem
Old Jun 27, 2006 | 10:13 PM
jcv177's Avatar
Default 2002 C230 Panoramic Roof Problem
Hello all
Problem with the roof.
The glass roof closes fine thankfuly but the before the plastic sun shade even begins to close the motor just begins a loud clicking/
grinding noise. Is there any way to manually close the sun shade until I can get it to the shop?
I have sent away for a owners manual but quite frankly my head is burning.
Old Jun 27, 2006 | 11:28 PM
sleepwalker's Avatar
Default RE: 2002 C230 Panoramic Roof Problem
there is a cranking tool including in your tool kit or inserted in user's manual.
crank the left side motor.
maybe you might need to pry off the lens of the dome lamp to access the hole.
[IMG]local://upfiles/1/67892A1707554DE484FB7460095563DE.jpg[/IMG]
Old Jun 28, 2006 | 11:56 AM
jcv177's Avatar
Sleepwalker.
I thought that might be what that thing is.
Thank you for the help.
Old Jun 29, 2006 | 12:09 PM
jcv177's Avatar
With sleepwalkers help and the following website -
http://www2.mercedes-benz.co.uk/cont...ve_manual.html
I can describe what the correct procedure for manualy closing the roof shade:
Turn off the car and pull out the key.
Pull off the large forward lamp dome.
This reveals two white sliding levers.
Push both levers towards the from of the car and simultaneously pull down on the entire light/roof switch assembly. (a tricky maneuver)
The entire assembly pivots down and then releases. (still attached to the car by wires)
This then exposes the motors
Use the key supplied with the car to slowly crank the appropriate motor.
It will take some time to fully close the shade.
In my car the shade was activated by the right hand motor.
Once I cranked it a few turns, it closed with the motor. I am however still having problems with the roof. When I open the shade normally, it will not then close. I tried to run the reset procedure but to no avail. I guess I still need to get it to the shop.
Thanks again Sleepwalker.
Hopefuly I'll get that manual soon.
03C230kCoupe
Jul 29, 2011 08:13 AM
h11kop
Oct 16, 2008 01:59 PM
h11kop
Jun 19, 2008 08:14 PM
h11kop
Jun 19, 2008 05:31 PM
jcv177
Sep 23, 2006 12:29 AM
