QUESTIONS ON YOUR BENZ's I CAN TRY TO HELP!!
Old 04-08-2009, 04:33 PM
crazcokie's Avatar
Hi Mar, Ihopeyou can help me. I just purchased a 91 mercedes a couple months ago and I ran into a problem today. I was parked facing downhill and coul not get the car to go into reverse. I had to heve it pushed up th hill. I went to my local autobody shop and they checked the transmission fluid and it was full but metallicy. Could this be the problem or is it more serious? Any insight would be appreciated.
Janet
  #92
Old 04-10-2009, 03:08 PM
tarnason's Avatar
Default B200 Oil Filter Location
Do you happen to know where it is locatied?
  #93
Old 04-12-2009, 10:13 AM
danndragon's Avatar
Default never asked for advice on computor b4
I have '85 500sec with 200k car runs great but I think I should change trans fluild and filter any thoughts? after I log off Imight not be able to find this place again so if anyone could e-mail me Id really appreciate it!danndragon@yahoo.com
  #94
Old 04-14-2009, 09:01 AM
bbbs500's Avatar
Default Aux fans runs all the time
I have a problem with my Aux fan, whenever I turn on the car both fans run on what I think is stage three all the time. I supect that it has something to do with a relay or control module. I can't find relays or control mudules to at least have them looked at. I would like to aviod a trip the the dedaler if I could find and replace these parts myself.
My car is a 1994 S500 with 140,000 miles on it. The tranny, blower motor, blower motor regulator, passager side door check and centrel door lock punp were replaced last season.
  #95
Old 04-16-2009, 07:30 PM
moisturev's Avatar
Default 2000 slk radio
Hi Mar,
My radio seems to be working, IE tunes to stations etc, only no sound?
All fuses seem to be ok?
Any help would be appreciated!!!
Thanks,
Patrick
  #96
Old 04-25-2009, 04:44 PM
mikehammer's Avatar
anybody with a fuse chart for a 2003 sl500 missing from the tool kit.thank you.
  #97
Old 04-26-2009, 08:36 PM
cdaviswall's Avatar
Default Mercedes S500
I have a 2000 mercedes S500 and have been experiencing random starting problems that might happen one day then not again for a couple of days. The car sounds like its trying to turn over but can't, I can try an hour later (or longer) then it starts right up as if nothing happened. Now the car is dying while I'm driving it and won't start up for several hours then starts right up but will die if I slow down or come to a stop.
  #98
Old 04-28-2009, 02:39 AM
GROUDEN's Avatar
Default grouden
hi , can you tell me if there is an easy way for me to change the starter motor on an A CLASS 160 PLEASE
  #99
Old 05-05-2009, 09:42 PM
entourage's Avatar
my 03 s430 rear suspension squeaks when i go over minor bumps,maybe a bushing,have you ever heard this
  #100
Old 05-06-2009, 06:58 AM
ricka360's Avatar
Default Heater fan not working
I took my 1998 s420 out of storage this Spring and battery was dead. Now that it's charged up everything works except the fan for heat & ac.
I don't have an owners manual so I thought I'd asked if anyone could let me know where I should check to fix the problem. Thanks in advance.
Quick Reply: QUESTIONS ON YOUR BENZ's I CAN TRY TO HELP!!
