Questions on your benzes, i can try to help!!!
Old 05-14-2009, 05:31 PM
djblosser's Avatar
Default E320 cd changer "clicking", won't open.
The cd changer door won't open and is making a clicking noise? Any ideas?
It's a 2005.
Thanks, Don
  #62
Old 05-15-2009, 11:15 AM
speddy's Avatar
Default Alarm
I have a 2004 C240 4matic.The panic alarm doesnt work.When i hit panic on the key the lights do blink on and off but no alarm.I bought the car with 39,000 on it and it didnt work from day one .I changed the batteries in the key but still no alarm.I dont think the alarm itself is working.How do i activate the alarm to check it?Any ideas on these issues?
  #63
Old 05-15-2009, 02:45 PM
djblosser's Avatar
Default E320 2005 Satellite module?
Hello, my car has a button for satellite radio but apparently that is all.
What do I need to do to confirm this. What do I need to do to be able
to use the feature. I've heard there is a satellite module?
Thanks, Don
  #64
Old 05-30-2009, 09:31 AM
geoastewart's Avatar
2002 C class 220 cdi. Boot/Trunk will not open with fob/door button/or emergency key! Also cannot get rear backrest out [one piece seat]. geoastewart@hotmail.com
  #65
Old 05-30-2009, 11:26 AM
J_ulik's Avatar
Default DIfferences between '05 E320 and '06 350
I am trying to buy a used W211. The dilemma that I am facing is chosing between E320 and 350. Can anyone tell me what are major differences besides the engine size and a newer transmission? Which engine and year has more problems? Are there any persistent problems on any of these models? All help is greatly apreciated!
Zanks!
  #66
Old 05-31-2009, 07:44 PM
kmbach409's Avatar
I have a question about an 84' 300SD I'm hoping you can help me with. I found what appears to be an ECU under my passenger side floor mats. This module was unplugged and by the looks of the corrosion on the terminals it has been for a while now. I am curious as to the purpose of this ECU and what kind of problems it may have caused being unplugged for this extended period of time?
thank you
  #67
Old 06-01-2009, 09:54 AM
Dewey00's Avatar
Default O2 light
hey,
I have an 87 260E, and for as long as I've owned the car, the O2 light has been coming on spastically, sometimes it causes the engine to stall, any ideas?
  #68
Old 06-18-2009, 10:16 AM
Leardriver's Avatar
Hi!
A little direction would be fantastic. I have a 2005 E500 with an air conditioning problem. It was working 2 days ago, then started blowing warm air. I had a local shop hook up the guages, and the pressures were super high on both the high and low side, like 140 psi. They evacuated the system, it held vacuum fine, and started putting freon back in, until it got to 1.5 pounds, and the pressures were about 82 PSI each side, but it won't take any more freon. Still blowing hot air, and the compressor clutch doesn't sound like it's cycling on. Any ideas? is there a low pressure switch that needs to be bypassed to charge the system, or a climate control reset after a fault was detected? It's getting hot here!
Thanks in advance for your help.
  #69
Old 06-18-2009, 01:36 PM
danidani's Avatar
Default Rough Idle
Please help!
I have a 2003 CLK500 with 68,000 miles and when I stop the car and it idles there is a rocking motion (vibration back and forth) that is felt inside the cabin. I took it to the dealer and we have tried replacing the engine mounts, plugs and wires in addition to the gasket that connects the intake manifold to the engine. Although improvements have been felt… the rocking vibrating motion is light but still present. What else could be causing this?
Thanks!
  #70
Old 06-20-2009, 10:14 AM
anabase's Avatar
Default e320
I am looking for a used e320 4matic wagon, for $12k, maybe $14k. Do you have any suggestions about what model years to look for--or avoid? Are there any maintenance issues I should be aware of at certain mileages? A little reading online seems to suggest that I search for an '01 or '02 with a complete service history, and with the lowest miles I can afford. I've been driving Volvos for many years, and am unfamiliar with the Mercedes.
Quick Reply: Questions on your benzes, i can try to help!!!
