need help with 420sel
Old Apr 16, 2009 | 08:45 AM
montoise's Avatar
Default need help with 420sel
I was in the process of replacing alltiming chain guides,chain and tensioner(I'm not a mechanic)and in the process,i got the timing off.now,i can not turn the engine(by hand)more than a quarter turn left or right.I never did started the engine,just the turned by hand.Could I have bent the valves by turning by hand and being off on the timing.Where do i go from here?Thank you for your advice.
Old May 30, 2010 | 03:43 AM
jagclassic2002's Avatar
This is a job I have done with success, it will require help if u have not done this before, u are more than welcome to e mail me and I can try to help to guide you through this procedure, it is very important though NOT to continue trying to turn the engine or cams.
My e mail is jagclassic2002@yahoo.ca
I will need to know if you are changing the chain because it jumped causing valve damage or simply to replace beacuse of the mileage
albj72
Dec 18, 2008 05:37 PM
fabchef
Jan 24, 2008 05:47 PM
donervogel
Sep 20, 2006 12:07 PM
lexasgs400
Sep 11, 2006 07:11 PM
tllnya
Apr 2, 2005 01:26 AM
