1988 420SEL Cooling Fan Not Working NEED HELP
Old Aug 13, 2006 | 01:42 PM
lexasgs400's Avatar
Default 1988 420SEL Cooling Fan Not Working NEED HELP
have a 1988 420SEL with 309,000. It has one mechanical fan and one electric fan, I have noticed at idle the A/C is not blowing as cold and also it is getting warm. The electric fan that is mounted to the front of the radiator is not coming on. I ran a lead to the battery and it came right on, so the fan moter is good. I also jumped the two wires on the evap canister and that did'nt work. I also checked the fuse and it was good.
Does anyone know what I should check next?
Jason
jsmith2086@satx.rr.com
Old Aug 13, 2006 | 10:34 PM
lemonlib's Avatar
Default RE: 1988 420SEL Cooling Fan Not Working NEED HELP
try the fan relay..that usually goes bad..
I wish sleepwalker is back...he can tell were it is...
Lemon
Old Aug 15, 2006 | 03:35 AM
vytamenc's Avatar
the relay is inside the fuse box on the driver side
Old Aug 20, 2006 | 10:04 PM
riley1's Avatar
hey just a thought. im a newbie as well but have the same car and the same problem.. after a suggestion from a forum veteran i changed all the fuses.. my blower motor fuse looked good in every way but it was not! new fuse solved the prob
Old Sep 10, 2006 | 06:24 PM
deiseldwarf's Avatar
I would start by testing the fan circuit at the fan. Put the a/c on and back probed the connector. See if power is actually getting to the fan. That is a good start. THe other suggestions make sense too, but I like to rule out the component first. If that is good, then going after the control circuit makes sense. Hope that does soemthign for you.
Old Sep 11, 2006 | 07:11 PM
97dmsrS420's Avatar
He's already complete the initial logical test! Read his scenario! In agreement with other posters, he only needs to replace the relay, and he should be fine. If that, by chance, doesn't work, then he should consider other options.
ip650123
Jun 16, 2011 11:02 AM
ara662
Oct 8, 2006 08:29 PM
lexasgs400
Aug 13, 2006 01:40 PM
lexasgs400
ooisper
Mar 31, 2006 12:54 AM
