Changing Sunroof motor
Old Mar 9, 2006 | 03:32 AM
Nicopico's Avatar
Default Changing Sunroof motor
I have a 1986 300E and need to change the sunroof motor. Is it possible to leave in the existing cable and change only the motor. if so how do i remove the motor from the cable and tubing? THANKS
Old Mar 9, 2006 | 03:40 AM
sleepwalker's Avatar
Default RE: Changing Sunroof motor
yes.
remove the big lock nut on the shaft.
Old Mar 9, 2006 | 11:57 PM
Nicopico's Avatar
Thank you sleepwalker is that the threaded bolt with the lock nut located in the middle of the unit (just under the sunrood motor)
Old Mar 10, 2006 | 02:21 AM
[IMG]local://upfiles/1/D75F6A995550486E8574C09FC733E855.jpg[/IMG]
xb70valkarye
May 8, 2026 08:01 AM
CollectiveSoul
Feb 18, 2007 03:54 PM
cargibbs
Oct 14, 2005 06:09 AM
jvision09
Mar 29, 2005 04:28 AM
190e 2.6
Dec 5, 2003 01:01 AM
