sunroof relay/motor 230ce 1988
If you have access to an amp meter, see if you have any current draw when trying to operate the sunroof, or else, see if the interior light dims when you try to operate the roof. If there is no current draw or the light does not dim, check your switch. If it does dim, you probably have a problem in your roof that has jammed it.
The motor is in the LH side of the boot, below the rear screen.
Good Luck,
Good Luck,
CollectiveSoul
Feb 18, 2007 03:54 PM
geth
May 23, 2005 10:49 AM
