190 E Tumbler Need Help
Old Jan 11, 2006 | 11:30 AM
hipping's Avatar
Default 190 E Tumbler Need Help
Hello all: I am in the process of replacing the tumbler on my daughters 93 model 190E and I am having a terrible time, in other words a 3 lb hammer comes to mind but I walk away a while. I have read several post on tumbler removal and they are very informative. This is what I am doing: I have used wires, paper clips and sizes from 1 to 1.5 mm to slide in the No. 2 slot, they go in approximately 1 inch. I cannot remove the outer shell or holder of the tumbler by turning ccw or pulling it out or anything. I have 2 holes 180 Deg. apart on the tumbler I am inserting the wires. You can wiggle the tumbler holder back and forth about a 1/16" either way but it will not come off. I have tried pliers, visecrips, but I am only chewing the black paint off. ANY HELP or suggestions would be GREATLY appreciated plus keep me from using a 3 lb hammer on the thing. Thanks a million
Old Jan 11, 2006 | 10:00 PM
sleepwalker's Avatar
Default RE: 190 E Tumbler Need Help
welcome.
maybe your tool is not of correct size? (the wire i mean)
it is really difficult to pull that out esp if the catch inside is broken. sometimes your blood pressure comes up first before the lock does.
[IMG]local://upfiles/1/30D052B3159E4D8796C16125FF579906.jpg[/IMG]
[IMG]local://upfiles/1/8C1A3F414CAC440498AA9CE2250BC920.jpg[/IMG]
Old Jan 12, 2006 | 01:37 PM
hipping's Avatar
Sleepwalker: Thanks, Couple of other things, does the collar thread off the tumbler or does the Tumbler and all come off at the same time. I guess what I am saying is how is the proper way too remove it. Pull, twist, does the tumbler and collar all come off in a unit. Is there anything I should feel for. Again Thank you very much.
Old Jan 12, 2006 | 11:18 PM
C280 wizard's Avatar
Sleepwalker: these pics come in very handy. I also have a problem with tumbler on my 450SLC, the flap that covers the opening is stuck in the open positio. I took a pick with a 90 degree angle and got it half way closed, but as soon as I inserted the key and removed it the flap stayed openb. I know they are spring loaded and in the past I have had this happen on various cars, and something I got lucky with a piece of wire or pick, but this time it seems as if it is out of a mount, or something inside that hold it vertical to the opeing?
Any suggestion PLEASE!
Al aks C280Wizard
ORIGINAL: sleepwalker
welcome.
Old Jan 13, 2006 | 01:53 AM
the collar first because it serves as the retainer for the barrel.
please see the diagram again with instruction.
[IMG]local://upfiles/1/7F56F93DE1EB4F72B33F5818A8939706.jpg[/IMG]
[IMG]local://upfiles/1/BD574CF34141438285142B4E3FEA3524.jpg[/IMG]
Old Jan 13, 2006 | 01:57 AM
flap that covers the opening is stuck in the open position
yes there is a spring inside.
the only reason that it cannot go back is because it touches something. the spring tension is not strong enough to bypass the obstruction.
have you tried spraying a bit of WD40 on it?
Old Jan 13, 2006 | 12:18 PM
hipping's Avatar
Sleepwalker: I Got it. MANY MANY Thanks. Now I have to put the starter back in and boy was it a pain to get out, especially that top bolt. Any advice here. Again Thank you.
Old Jan 14, 2006 | 12:38 AM
do the easy bolt first hand tight.
Old Jan 21, 2006 | 10:13 PM
  #9
dbenz's Avatar
The 190 tumblers are a common problem as they get older.
honeybee
May 30, 2007 10:26 PM
slow
Nov 22, 2006 02:18 AM
peppermcgee
Mar 14, 2006 08:57 PM
protoman
Dec 6, 2003 01:50 PM
