WANT alternator mounting bracket
Old Apr 9, 2016 | 03:36 PM
cult colt's Avatar
Default WANT alternator mounting bracket
I have a 1981 W123 240D. Does anyone have or know where I can find an upper alternator mounting bracket? It has a long adjusting bolt as part of the bracket. The bracket seems to be bent in some way. When I adjust the belt to proper tension the adjuster bolt is bent and the belt is almost rubbing against the alternator fan( the one behind the pulley on the alternator). Has anyone had a similar problem? Does anyone know what size belt is correct? I've been driving it like this but the clearance seems too small. The belt doesn't rub the alternator fan during normal operation but I notice a tiny amount of fraying on the edge of the belt. Any advice on this matter? Thanks.
member300sd
Sep 29, 2014 01:51 PM
NealH
Aug 2, 2008 03:03 PM
Max In Montreal
Nov 22, 2006 11:26 AM
sjett
Dec 23, 2005 10:51 PM
eburoon
Nov 23, 2004 09:37 PM
