broken locks/door/window
Old Sep 10, 2007 | 02:53 PM
junebugek's Avatar
Default broken locks/door/window
I have an '85 300TD.The passenger side rear door will not open and the window does not work. My driverside door does not lock at all. And supposedly my car will automatically unlock all 4-doors when I put the key in the driverside door, but this doesn't work either. Any suggestions or good web-sites I should check out on how to resolve this issue? My first hunch is to check for vaccuum leaks, but I don't htink that's it because it's only the one door.
Thank you.
Old Sep 10, 2007 | 06:32 PM
carnut's Avatar
Default RE: broken locks/door/window
Try www.dieselgiant.com to trace vacuum leaks. Check fuses for window being inop.
stevel
May 30, 2017 11:37 PM
bdaved
Nov 12, 2011 01:32 AM
fraguada1
Aug 27, 2011 05:55 AM
leytonorient
Mar 31, 2009 04:53 AM
gaby7588
May 28, 2008 04:40 PM
