300SDL HELP URGENT
Old Sep 7, 2007 | 04:49 PM
99S420's Avatar
Default 300SDL HELP URGENT
Guys, as you may recall, I recently acquired my 87 300SDL, with 86K miles. There are two things I need help with please:
1. What is the engine temp supposed to stay at. I drove the car on the highway today, and had the A/C on and it ran pretty high to about 108C, which worries me...with the A/C off, it stays just under 100C. I know that if this car overheats, there are big problems with the head cracking......any thoughts. Maybe this is normal, and I am overly paranoid.
2. The car runs beautifully, has great pickup and great highway cruising.....I MEAN GREAT. This car is far superior to the 84 300SD I had in terms of pickup and performance. HOWEVER, after getting off the highway and perhaps coming to a stop or red light at the ramp, the car will just shut off, when idling for a minute....this is quite strange....I also noticed that it idles at 5RPM, which seems low, compared to my 300SD, which idled at 7-8RPM....Thoughts?
As a side note, I am so surprised how quick the car is and the fuel economy is not bad...I got 300 highway miles on 1/2 tank today.....
Thoughs Guys on the 2 questions?
Tom
Old Sep 7, 2007 | 05:03 PM
polyglot's Avatar
Default RE: 300SDL HELP URGENT
I had a similar problem with my '97 E300D--frequent overheating, i.e., 100+C instead of the typical 85-90-ish. It was NOT the thermostat and turned out to be a fan that had to be replaced.
Old Sep 7, 2007 | 05:35 PM
99S420's Avatar
Thanks. I know the fan is useful only at low speeds....But I even have the problem at high speeds.....
Old Sep 10, 2007 | 03:11 PM
Dallas 300SDL's Avatar
What is considered overheating on the 300SDL? In other words, how hot is too hot? I was driving on a hot and humid day in traffic the other day in Dallas and the temp needle was sitting between the half way mark and the "all the way too hot" mark...it concerned me but never got any hotter.
Old Sep 10, 2007 | 04:41 PM
99S420's Avatar
Well, it was slightly above the 100C mark, probably around 105 - 107.
In my book, that is pretty hot, I dont like to run em that hot.
Old Sep 11, 2007 | 09:35 AM
Mr.47's Avatar
Hi
My84 300SD dose the samethingoverheating i would suggest to take that thermostat out for thesummer timeand replace it back inwhen winter time comes aroundI hope this helps.
THX
Old Sep 11, 2007 | 10:00 AM
99S420's Avatar
Thanks Mr. 47. I decided to take the car in to the Mercedes service - they told me its the thermostat that needs replacing......
Appreciate everyone's input though...
By the way, I used ot have an 84 300SD - it was the best car I ever owned.....
Old Sep 11, 2007 | 02:09 PM
AMGMercedes's Avatar
Thermostat is an easy replacement. Lucky it's not a fan clutch or radiator. lol
Old Sep 11, 2007 | 02:44 PM
  #9
99S420's Avatar
AMG, they called me and told me the fan clutch needs to be fixed as well.....Since I am doing this, I am going to give you guys a heads up about what is getting fixed and what its going to cost:
1. Drivers side window motor and regulator
2. Glow plug is out and needs to be replaced
3. Fan clutch and coolant thermostat
4. Sunroof motor needs replacing
5. Brake pads on all 4 wheels
6. Radio repair
Grand Total: 3,500-
Unbelievable, but, its for my baby, so I dont mind taking care of her.
Tom
Old Sep 12, 2007 | 09:53 AM
  #10
mbz300sdl's Avatar
Damn i would have done it for 2k i had an 86 300sdland all that stuff is easy! Glow plugs are simple to replace, radio depending on problem, brake pads on these cars are the easyest of any car i have ever seen u dont have to take the caliper off!!!
Sun roof and window take it to an upolstry shop less cost and they normally do a much better job than dealers or regular shops sorry i didnt see this sooner!
BTW i have a oil filter leftover from when i had my sdl send me a PM if u want to buy it its a Hengst filter not some cheap autozone brand
