How to fix broken window switch?
Old Apr 20, 2009 | 10:32 PM
stevel's Avatar
Red face How to fix broken window switch?
I have a 2003 C240 in which the window switches are located on the door handles, not the center console/transmission housing. One of the driver-side window switches (for the front passenger window to be exact) has broken and is still usable but the button comes off completely. If I fix this, do I need to buy the whole module (i.e., all 4 window switches) or can I just replace the single broken toggle?
Thanks for reading!
Old Apr 21, 2009 | 11:57 AM
mrcoyote's Avatar
Talking
Same thing happened on my '05 C230K. I replaced the one switch only. The driver's window switch commonly goes before the others because of the frequency of use, obviously. Not a big deal to do the job.
Old Apr 30, 2009 | 06:23 PM
stevel's Avatar
Default How do you do it?
How much was it and how did you remove it (do I need to take door apart)? I guess 'switch' is a bad term since I really only need the black plastic piece with the picture of window on it. The switch behind the piece is fully functional.
Thanks!
Old Oct 6, 2010 | 07:53 PM
Sceebo's Avatar
Default How did you do it?
Well this is an old thread but hopefully someone will have an answer. How did you replace the switch without breaking it?
I recently bought an 04 clk500 for the wife and the window switch was broken by the detail person the day I picked it up. I bought an entire module off ebay for $50 just to get the plastic switch and now I just want to pull the switch off the one I bought and put it on the one in the car. I just don't want to break it in the process. That would not be good.
Any advice would be appreciated. Thanks
Old Dec 15, 2011 | 04:51 PM
Lisa Graham's Avatar
Default Driver side window
I have a C 240 '02. Driver side window control has been broke for a while but with patience it will go up. Tried to put window up today it did'nt work. How can this be fixed?
Old Dec 19, 2011 | 02:07 PM
big Al's C220's Avatar
Hiya, as an emergency measure, exit your car, hold down the lock button on your key fob until the windows go up, if that fails, try locking it first, then holding down the button.
That method works for my 55 plate C220.
My driver button is broken, so has anyone actually replaced the button itself? Or is it a case of replacing the whole unit??
Old Jun 9, 2016 | 06:53 PM
Skye's Avatar
I have created a video you might be interested about the button repair and it won't cost you a dime (unless you want to buy a button) PLUS you can repair it in less than a minute! Click my free YouTube Video:
Old May 30, 2017 | 11:37 PM
drnapier's Avatar
Smile Drivers window switch
Hi Skye, trust all is well with you. First of all, thank you for video on how to repair a broken switch, in my case, it was drivers side window that would not come up. My vehicle is Mercedes 2009 C300. I check first to see if a fuse was blown, the 2&3 were fine. After a google search, I came across your video which was right on point. I replaced the rear switch with the front and as quick as you can say up and down, my window is now working. I will look around for either replacement switch or the whole module. Again thanks.
ifthecar
May 12, 2013 02:07 PM
ifthecar
Nov 7, 2012 12:16 PM
fraguada1
May 18, 2009 12:39 PM
leytonorient
Mar 31, 2009 04:53 AM
benzE320
Feb 27, 2008 01:27 PM
