How to replace climate control light bulbs?
Old Dec 2, 2006 | 01:58 PM
scarabexc's Avatar
Default How to replace climate control light bulbs?
2001 320 SLK, AC controls are dark at night, dealer says $210.00 to replace the two bulbs!!! Says it's a two hour labor job. Can someone give me a tip on how to do the job myself please? THANKS!!
Old Dec 2, 2006 | 05:15 PM
WB9AXO's Avatar
Default RE: How to replace climate control light bulbs?
Been there, done that. I was told the entire dash would have to be disassembled! [:@]
On my '98 SLK230, the fan **** and the position **** both pull straight off. Beneath each is a small bulb under a small white plastic shield. Carefully push the shield aside, grasp the bulb and pull (I used needlenose pliers - CAREFULLY). Take the bulb to Autozone (or equivalent) and have them match it. I got 2 for $3. I used the needlenose to reinsert the bulb. Then pop the ***** back on.
I just saved you $207.00!! Send me a check
Old Dec 2, 2006 | 09:43 PM
scarabexc's Avatar
Thanks, I also asked the dealer to replace the left dome bulb while my wife was having the code reset on the radio, they told me the circuit board on the back of the dome light assembly was cracked and the complete unit had to be replaced, one hour labar, and $200.00 for the part. Well BS, I removed the assembly in about 3 mins, there is no circuit board, and the only problem was the bulb was gone, and on top of that, they somehow blew the fuse to that and the door locks, can you beleive how they try to rip people off!! Had they been honest, I would have been a customer for life. Thanks again.
Old Dec 3, 2006 | 02:37 AM
WB9AXO's Avatar
Glad to help. Dealer service is necessary for some things, but many of the day to day things are pretty easy with the right help. This board, MBWorld and BenzWorld are tremendous resources for help and advice. [sm=groupwave.gif][sm=groupwave.gif]
Old Dec 3, 2006 | 01:44 PM
BikerDrew's Avatar
Welcome to our play ground. As you can see, you can solve almost anything here.
Old Dec 13, 2006 | 08:30 AM
bazzle's Avatar
Use plastic hose/tube to remove globes, no chance of breakage.
Bazzle
pawlovich_wayne
Jun 19, 2008 09:34 AM
scarabexc
Dec 6, 2006 09:54 PM
BenzoDJ
Nov 23, 2006 04:12 PM
kenf1144
Aug 28, 2006 04:15 AM
