Electrical Voodoo
Old Jul 15, 2022 | 10:03 AM
MeanGene's Avatar
Default Electrical Voodoo
So I've had this 2004 SL500 for a couple weeks, and it started with the error warning "Electrical consumers offline". Strange, it had only been 2 days since it was driven, so supply battery shouldn't be way down. Tried to drive it a bit, throttle was unresponsive. Shut it down and fired back up for a reboot, and ran fine, error message gone. So I took it back for checkout (bought it from a Merc shop), and what I wanted checked was lost in translation between the girl in front and the tech- enough about that. So on the way home, I stopped a couple times, about a half hour first leg, came back out and fired up, all OK, made a phone call, and instruments suddenly bottomed out, then rebounded, SRS light came on, then I got an warning that the top was partially open which it was not. Instruments bottomed a couple more times. Got the big red battery light- car has both batteries replaced just before I got it, "Mercedes" batteries, and I checked both after the first episode and 14+ while running. Thought I'd get it moving, then the battery light went out and it settled down a bit and the SRS light went out. Stopped to eat, fired up and it's still having a spaz attack, AC started blowing dead hot, SRS again etc. Shut it off and rebooted, AC back to normal, again with the instruments. Got home and shut it off, checked service battery and 11.98 V(!). Start bat 12.7. Started it back up and 14+ at both. So I have a good NOCO charger with low amp and AGM setting, overnight came up to 12.56, short drive and it was 12.10(!). Charged it again and let it sit a couple days, service is 12.08V. Charged it for a couple hours, came up to 12.26, so I'm thinking it should charge up while driving, went to lunch, it's fine, stopped at H Depot, came out and spaz attack again, see the shop, error saved, SRS light on and off, top open light again. Get home and 12.08V. This thing had a LOT of work done on it just before I got it, including new suspension and brake modules at many $. Why is it not charging the serv battery properly? I am aware the low voltage makes these things unhappy, but it shows 14+ when running, idle with AC on. New batteries can be bad, seems like it show be charging up better? I let it sit for a couple hours to settle down and checked amp draw at the neg cable, .19 to .2 amps which seems pretty good. At this point, I am not impressed, and driving my XK8 that is bulletproof WTH? I have ordered a phone charger with amps/ volts digital display, since this thing does not have a voltmeter (!) It has only done this after fully warmed, then sits a while, then drive again- hmm, heat soak on something? Charging just fine sitting in the driveway. icarsoft MBII coming today
MeanGene
Jul 13, 2022 10:13 AM
gdegeorge
Jul 31, 2017 06:28 PM
nbrock_85
Sep 12, 2010 10:42 AM
geminichrisw126
Apr 26, 2010 09:21 AM
melli33
Apr 20, 2008 12:33 AM
