clock spring/steering and angle sensor replacement
Old Oct 29, 2018 | 02:42 PM
whitcre1's Avatar
Default clock spring/steering and angle sensor replacement
i am trying to replace the steering angle sensor and clock spring on my 1997 sl500. i have removed the steering wheel and the 2 screws in the clock spring. the clock spring feels like it is caught on something or a tab needs to be pushed. anyone done this before
Old Nov 5, 2018 | 01:27 AM
brookings's Avatar
fortunately I haven't had the pleasure of having to get into my 129's steering assembly yet, so I have no hands on. might check for pins or spacers between the spring and shaft. should be wedge shaped arrows pointing to the retainers or a place to pull. my slk clock spring was held down by only the two four wire connectors under the spring in the area of the screws. I pulled the spring off the connectors by hooking under it next to the steering shaft. work your way around the shaft. don't break anything, gentle.
glen washington
Jan 19, 2015 06:08 PM
hotfuzz123
Nov 12, 2010 02:22 AM
Sepherial
Feb 26, 2010 02:03 AM
Northernstar
Nov 30, 2007 06:00 PM
ioang26
Oct 31, 2007 12:23 AM
