combination switch
remove air bag, remove steering wheel, loosen the screw at the bottom of the steering column, same size as the airbag screws. pull off the whole steering column unit/cover. then disassemble the column, steering angle sensor, and clock spring. this might be something you should have a shop do.You have to be mindful of keeping the clock spring and steering angle sensors at the right place when installing.
dbcooper
Feb 9, 2005 10:26 PM
