Combination Switch
Old May 24, 2005 | 04:12 AM
k_alavi's Avatar
Default Combination Switch
I need to replace a combination switch in a 97 E320.
Is this relatively easy?
Any special tools required?
How do I remove the cover on top of Airbag to begin with? Where are the screws for the cover?
Old May 24, 2005 | 12:31 PM
sleepwalker's Avatar
Default RE: Combination Switch
easy.
from the back of steering wheel.
Old May 25, 2005 | 10:00 PM
k_alavi's Avatar
Sleepwalker,
There are two holes in the back of the steering wheel. I cannot see inside the holes, but It feels that I can engage a mid-size flat head screw drive. It is very tight both clockwise and counterclockwise. The tip of my screww driver was bent. I did not want to apply too much force for the fear of breaking something.
What is insde the wholes and how do I get the airbag cover out?
Do you have any pictures or diagrams?
Thank you very much.
Old May 25, 2005 | 10:49 PM
not flathead.
it is torx.
Old May 25, 2005 | 11:09 PM
k_alavi's Avatar
Thank you sleepwalker,
I have to go and buy the tool. Should I use alen wrench type torx or screww driver type torx. Do you happen to know what size?
Thanks.
Old May 26, 2005 | 12:41 AM
torx 30 if am not mistaken.
at least 70mm long because it goes deep. too long will not give you enough space also.
the L-type got more power on it.
just disconnect the battery while doing it so you won't have a mercedes-benz mark logo on your forehead if ever it deployed accidentally.
if need radio code, just give me your radio serial number.
Old Jun 4, 2005 | 12:21 AM
k_alavi's Avatar
Thank you Sleepwalker.
Good News: I replaced the combination switch and it is working fine.
Bad News: When I start the car, the SRS red warning light goes off for a fraction of a second and It comes back on and stays on. Yes I checked and rechecked that the wire plug is connected to the airbag unint. Disconnected and reconnected the battery. Now it seems that I have a bigger problem to solve. Do you have any ideas Sleepwalker? Thanks for all your help.
Old Jun 4, 2005 | 06:15 AM
did you mess up with that clockspring unit? check if you didn't pull it too tight while steering.
there's an open circuit.
Old Jun 25, 2005 | 12:28 AM
  #9
k_alavi's Avatar
Sleepwalker,
I just bought a new clockspring and replaced the old one. The SRS warning light still comes on.
Do you have any other advice?
Old Jun 25, 2005 | 02:40 AM
  #10
just delete the fault code.
take it to the place where they got the scanner.
