alternator on the r230sl
Old Mar 10, 2020 | 08:26 PM
brookings's Avatar
Default alternator on the r230sl
at first I noticed a little flickering from my dome light at idle, at the time I didn't think anything about it until it finally went out. when it finally goes it won't take long to drain your battery and your dash will light up. The sbc will go, brake warning lights and battery light, then comes the alternator warning and you have at most an hour to replace the alternator even with a full battery charge. replacing it isn't all that easy either. first the alternator is in very tight where it mounts. if you remove without removing hoses you can manipulate through the hoses toward the front. you need to remove fan assembly. the dome light doesn't flicker anymore after replacing and all is well again in the universe
GregInJrsy
Jan 11, 2018 11:35 AM
brsilves
Jan 23, 2016 07:46 PM
04 C230Komp SoFLgal
Oct 28, 2010 08:31 AM
86300Eer
Jan 19, 2008 11:51 AM
mbgt
Nov 11, 2006 09:06 PM
