500sl problem starting when warm
The car starts on the button when cold .drive for a mile or two stop and try to restart the engine and it seems to have a bad missfire then will clear its self . apart from the starting when hot the car runs ok
....can you HELP PLEASE......
leaky injectors maybe flooding or vapor locking the engine. back-flow check valve at the fuel pump may allow fuel to drain back losing pressure. basically when fuel is not under pressure it can boil when the engine is hot.vapor lock. somewhere between the injectors and the fuel pump you are probably losing pressure. a bad four wire temperature sensor on the water pump housing can cause hot start issues too. this isn't written in stone. good luck
Turn on the key on goes the compressor clutch climate control haste no control
Over the compressor on off condition. Dose this sound like a shorted wire in the system thanks again jpforazda
Hi, this is my first time on this plat form. I have a 2001 c240 with a mileage of 139788 and I'm currently experiencing hard starting in the morning and delay in acceleration even when warm. Pls can anybody help with solution or a tip on how to solve the problem? Thanks.
Brooksy_p1
Aug 7, 2009 04:42 AM
