rear wheel locked up and transmission would not shift into lower gears
Old Aug 27, 2011 | 06:52 PM
dkferrell's Avatar
Question rear wheel locked up and transmission would not shift into lower gears
Stored my 99 ML 430 for 4 months in a relatively dry warehouse. Disconnected the batttery. Decided to check on the car. Reconnected the battery cables and started right up. After putting it in drive the rear wheel appeard to lock up. After putting in reverse then drive several times it loosened up. Transmission will not go into to lower gears. Need assistance.
Old Sep 8, 2011 | 11:14 AM
mbenz80's Avatar
Did you apply the parking brake when you stored it? Sounds like stuck emergency brake shoes.
Check transmission electrical connector for fluid contamination and scan it for codes. (Solenoid mulfunction)
LeoKei
Sep 16, 2015 10:09 PM
LeoKei
Mar 7, 2010 02:38 PM
seblani
May 19, 2008 06:55 PM
dinandriver
Apr 15, 2005 05:09 PM
