Front Wheel Disc problems ML430
Old Jun 13, 2009 | 02:03 PM
biolaolaleye's Avatar
Default Front Wheel Disc problems ML430
I hear noises from the front wheels, I have changed bearing twice to no avail.Also,there is a wobbly movement whenever I press the brakes and getting to a complete stop as if my front tires are worn out. The tyres are new,the pads ok and callipers serviced severally. I have changed the discs twice, there was a temporary respite the last disc changed it has started again
Old Jun 15, 2009 | 01:05 PM
mbenz80's Avatar
I would check lower ball joints (163 330 01 35)as they will make creeping noise while comming to the stop or over speed bumps, if they are dry. I was blaming my brakes too, then I lay under the car and had someone move suspention up/down to pinpoint it. Greased it with needle at the end of greese gun fitting and never heared any noise since.
slyc230
Apr 19, 2024 10:10 AM
sasjzl
May 27, 2006 10:27 PM
Gary
Jan 8, 2006 04:33 AM
C280 wizard
Sep 22, 2005 01:19 AM
C280 wizard
Sep 9, 2005 04:09 PM
