Front Wheel Disc problems ML430
I hear noises from the front wheels, I have changed bearing twice to no avail.Also,there is a wobbly movement whenever I press the brakes and getting to a complete stop as if my front tires are worn out. The tyres are new,the pads ok and callipers serviced severally. I have changed the discs twice, there was a temporary respite the last disc changed it has started again
I would check lower ball joints (163 330 01 35)as they will make creeping noise while comming to the stop or over speed bumps, if they are dry. I was blaming my brakes too, then I lay under the car and had someone move suspention up/down to pinpoint it. Greased it with needle at the end of greese gun fitting and never heared any noise since.
