Wearable Rotors
Old May 10, 2006 | 01:04 PM
EdelweisB's Avatar
Default Wearable Rotors
We have a 2003 E320 with under 30k. The brake check display recently came on and we took it to get repaired. We were told that the rotors had to be replaced as well because they were wearable as well. In fact, it was said, that Mercedes rotors should be replaced every other brake job. Anyone know if this is true about Mercedes rotors, especially newer ones (2003?)? I've never heard about rotors that wear so quickly...and we do regular brake jobs. Any feedback would be greatly appreciated.
Old May 10, 2006 | 03:22 PM
jackd's Avatar
Default RE: Wearable Rotors
yes, this is true.
I've own my W124 since 1991 and front rotors were always replaced every other brake job. That how the beast like to be fed.
For many trying to use harder brake pad for longer pad life, it is not uncommon fro rotors to need replacing when the pads are worn.
Old May 10, 2006 | 03:40 PM
K1MOTORSPORT's Avatar
Since rotors need to be replaced, maybe it's good time to upgrade to drilled rotors and high performance brake pads.
Old May 10, 2006 | 03:41 PM
By the way, above pic is KVR rotors. We offer complete customization.
Old May 10, 2006 | 04:49 PM
EdelweisB's Avatar
Advantages of drilled rotors? Cons?
Old May 10, 2006 | 04:56 PM
It helps wipe away the debris that forms between the pad and the disc, adds more bite, and appearance is much more sporty. There are no cons.
ORIGINAL: EdelweisB
Old May 10, 2006 | 07:36 PM
mbz300sdl's Avatar
ORIGINAL: K1MOTORSPORT
ORIGINAL: EdelweisB
I have heard and read that drilled rotors can crack and break. Personally i like slotted and dimpled cause they offer the same affect without the possiblitiy of cracking. Though the cracking is rare i thought u should know about it.
Old May 10, 2006 | 08:50 PM
Right, drilled rotors rarely crack and normally happens to low-quality rotors. Purching drilled rotors from reputable manufacturer should be fine. Dimpled rotors are another great alternative.
ORIGINAL: mbz300sdl
EdelweisB
May 10, 2006 04:47 PM
darqlorde
Jun 28, 2004 10:53 PM
mrthor
Jun 8, 2004 11:00 AM
Saliya
Dec 27, 2003 10:44 PM
eurocarsnut
Nov 20, 2003 04:32 PM
