Transmission pan leaking, 2000 E320.
2000 E320 rwd w/75k miles
There is a transmission fluid leak all around the transmission pan seal. Would this be a good time to change the trans fluid and filter? I would really appreciate a view of the pages in the repair manual that covers this repair. Thank you
Marty
Marty
you should get this fixed ASAP. nothing worse than blowing that year transmission and overhaul would be spendy!
Here is a DIY http://www.mercedesshop.com/Wikka/Trans7226Fluid
i think the 2000 e320 has the 722 tranny but i may be wrong, you might want to check with your dealer/mechanic
I ordered the parts and the dipstick tool. What's the normal operating temp for the trans, is it about the same as the engine? About 90C? Sleepwalker or any MB tech, do you actually use a temp gun or do you just check the trans fluid level when the engine has reached normal operating temp?
