Stuck in 1st
Old Dec 15, 2003 | 02:04 PM
GirlTrixta's Avatar
Default Stuck in 1st
I have a 1999 automatic E320... for some reason I went to drive it one morning and it never left first gear. I immediately realized what was happening and turned around and headed home. What could be wrong?</P>
Old Jan 28, 2004 | 11:45 AM
oldcorollas's Avatar
i have found a similar problem with our E320 as well.. previous day was changing fine, then next would only reluctantly change out of first.</P>
auto fluid is a little on the low side, but not alarmingly so.</P>
any suggestions apart from draining box and doing fluid/filter change?</P>
Cya, Stewart</P>
</P>
Old Jan 31, 2004 | 04:04 AM
<SPAN class=bold>Girltrixta, check the fluid level in the auto box.</SPAN></P>
<SPAN class=bold>our problem occured with the level maybe 3-5mm below the min mark, but suddenly happened after a hot day (like 30-40deg), even though the level had been low for a long time. put in some fresh fluid, problem mostly went away, but would select 1st when starting 'hastily'</SPAN></P>
<SPAN class=bold>a service with fluid and filter change in the gearbox will happen next week. see what difference it makes.</SPAN></P>
<SPAN class=bold>Cya, Stewart</SPAN></P>
<SPAN class=bold></SPAN></P>
Old Feb 8, 2004 | 02:41 AM
maloneauto's Avatar
You may have got you gear shifter wet. Very common because the cupholder drips into it. Mercedes wont warranty it either. Very bad design. Shifter cost about 400.00
GMFuzy
Jan 11, 2015 03:21 PM
pmac
Jun 17, 2010 09:18 AM
5 Salt
Feb 4, 2008 09:25 AM
Warren C
Jul 25, 2006 09:15 PM
gqgifts
Sep 1, 2005 05:06 AM
