Spark Plugs
Just brought my car in for Service B @ 70K miles. Total bill was $900.00 including a new air filter, coolant flush and new fuel filter. They also wanted to put in new plugs for $570.00. Holy crap, I think I'm still capable of changing my own spark plugs. Question is what brand does Mercedes use? I have an '01 E320. The dealer wants $18.00 per plug, but I could buy Bosch platinum for $6.00. Considering that the car needs 12 plugs the $$$ is pretty significant. Any comments on Bosch platinum? Any other recommendations? Thanks in advance.
Why do you need new plugs? Usual change point is every 50k, at least in Europe?
I would use Bosch (used as standard equipment) and stick to the Bosch after market recommendation for your model / type, should you choose not to use MB OE due to cost.
Stuart
Stuart
ORIGINAL: snanceki
Stuart
Stuart
Thank you for letting me know that Bosch is the OEM plug supplier for Mercedes. That basically was my original question.
ORIGINAL: Shovelhead
If you change the plugs yourself, be careful gapping them as the center electrode is very small. Also, use a little anti-seize compund on the threads, and torque according to what your owner's manual says. IF you've changed plugs before, you already know all of this.
I already changed my plugs at 50K miles because I was afraid of the plugs seizing up in the cylinder head after 100K miles. The job took about 2 hrs, and I found it easier to remove the coil packs to get easier access to the plugs.
Regards,
paul...
azdesertDog
Aug 24, 2004 11:30 PM
