New member - two questions
Old Apr 16, 2006 | 11:58 PM
sdelsolray's Avatar
Default New member - two questions
Hi. I'm a new member and new owner of a 97 E320. I have two questions:
1) Similar to a recent post, the check engine light has come on and the engine is running rough, like it is missing. The check engine light stays on after turning off the motor and restarting. Once, after the engine had cooled down, it started and ran fine, but a few minutes later it started missing again. We just bought the car and it was running fine, and drove it for about 50 miles - no problems. I realize I'll need to have the code read to attempt to isolate the problem. I'm just wondering if this is common, or if there are a few common problems which may cause this.
2) I would like to get a code reader as well as some books or manuals that explain the codes. Where can I purchase them? I would also like the code reader to work on my 2000 Range Rover, which I beleive has the same "standard" code system (I can't remeber the acronym - OBDI?).
Thanks!!
Old Apr 17, 2006 | 12:33 AM
sleepwalker's Avatar
Default RE: New member - two questions
it's really better to read the fault code since the problem is temperature related.
camshaft and crankshaft sensor reacts to high temp when nearing the end of it's life.
Old Apr 17, 2006 | 01:03 AM
sdelsolray's Avatar
Thanks for the quick response. I just checked it again after letting the car sit for 2 hours and it runs just fine. I'll have the fault codes checked and report back.
Old Apr 21, 2006 | 12:51 AM
sdelsolray's Avatar
Just an update. Turns out it was one of the ignition coils. It was replaced and the car runs fine fine fine. BTW, the mechanic said the wiring harness has already been replaced, and recently. He said the car was in superb shape, well maintained. Thanks for the help.
s40guy
Jan 27, 2009 02:59 PM
tima
Mar 18, 2007 12:03 AM
Kramerdude
Aug 22, 2006 11:06 AM
Baltimore_190d
Jun 9, 2006 01:34 AM
mopar460
Feb 24, 2006 02:42 PM
