Radio Reception
Old Apr 26, 2005 | 03:15 PM
rlteotico's Avatar
Default Radio Reception
My reception is bad on my 99 e320. How do i fix it? Could it be the antenna adapter is unplugged. I wen to the back of the car and noticed that a piece similar to an antenna plug was not plug into anything. Help. Im tired of listening to cd's. Thanks
Old May 3, 2005 | 08:39 PM
BigFP's Avatar
Default RE: Radio Reception
I dont know if I can help you but the antenna in mine (97 e320) is in the rear windshield and the connector is in the left rear panel.
I have a similar problem from time to time specially with AM reception but not that bad that I have to listen to CD's all the time.
Old May 4, 2005 | 01:06 PM
rlteotico's Avatar
What am i looking for exactly? I looked in the left rear panel and there are to big block things that are mounter on the side. I took the radio out and i noticed that the antenna adapter is not plugged in.
Old May 10, 2005 | 04:03 PM
varnmd's Avatar
Is the reception just bad for AM, or FM too? I have had some problems with my '97 E420 on AM reception only, hearing the engine noise on weaker stations. Recently changed plugs and a couple bad plug boots, and had one bad coilpak replaced. AM reception does seem better now, so could have been due to EMI (electromagnetic interference) from the ignition system.
Old May 13, 2005 | 02:10 PM
rlteotico's Avatar
The reception is bad on my AM and FM. I have no clue on what to due. I get reception when im at home and as soon as i drive about 15 miles away, the reception begins to fade. I looked behind the head unit and plugged in the antenna adapter, but the signal is still weak. Any ideas? I dont get any noise from the engine.
Old May 15, 2005 | 09:59 PM
rlteotico's Avatar
I want to thank you guys for all your suggestions. I found the problem. I noticed that there was plug laying around underneath the stock stereo, the plug looked like a stereo mini plug, I then plug it in on the back of the stereo and now my AM/FM works perfect. Thanks
Old Jan 6, 2006 | 10:57 PM
par49iron's Avatar
I have the same issue with poor radio reception. How did you resolve the problem? where did you look to find the loose connector or whatever it was that fixed the problem? Really appreciate your help.
Old Jan 11, 2006 | 03:02 AM
moonbike's Avatar
ORIGINAL: rlteotico
Can you tell me how to pull the head(radio) unit out of the dash? It's a 90 300E with a stock Becker AM/FM cassette stereo.
thanks for any help.
Old Jan 11, 2006 | 06:38 AM
  #9
hawke's Avatar
I just had my rear windows tinted on my CLK, but now the AM radio reception is not so good.
Does anyone know where the arial and or plugs are that I should look at?
landsteam
Nov 5, 2011 09:26 AM
12steve
Mar 13, 2006 01:08 PM
Jmack
Dec 12, 2005 02:56 AM
Jmack
Dec 9, 2005 03:38 PM
par49iron
Sep 7, 2005 08:24 AM
