No radio reception & door remote works only when aimed to door handle.
Old Dec 17, 2007 | 11:07 AM
landsteam's Avatar
Default No radio reception & door remote works only when aimed to door handle.
On my 2005 C240 the remote door opener only works when you are rightnext to thedoor handle. I changed the batteries but it didn't help. Also the FM and AM radio doesnt get any reception. It's like the antenna is broken. Does the antenna control both the radio and the remote key control?
Old Dec 22, 2007 | 09:50 AM
landsteam's Avatar
Default RE: No radio reception & door remote works only when aimed to door handle.
It was the fuse. I replaced it now all is well again.
Old Dec 24, 2007 | 07:13 PM
kareemo's Avatar
which fuse was it, my door remote is very weak.
Old Dec 25, 2007 | 06:25 AM
jackdash's Avatar
Have 2001 C320. Fuse #8 controls the RF for the rear window antenna amplifier that allows for remote key entry and trunk opening using the RF, and boosts antenna reception for the radio. Those two symptoms point to either the antenna amp or some break in the antenna. You then have to be up colse to the infrared on the door to open the doors and trunk. I replaced my fuseand it blew again so I am off to the dealer!
Old Jan 7, 2008 | 09:18 PM
JLWrobel@comcast.net's Avatar
I seem to have the same problem with a 2002 C230K Coupe does anyone know if the fuse would be the same for my car?
Old Jan 9, 2008 | 06:29 AM
Shan's Avatar
It should be the same. It is a 7.5 A (brown) fuse located in the left side of the boot.
Old Jan 9, 2008 | 01:39 PM
Thanks for the quick response. The fuse tested okay and I tried to find another fuse that might be involved. The fuse layout does not refer to the RF or the amplifier and I thought that was strange. This is my first Mercedes and I enjoy the ride but a radio and remote working would be nice.
PS. I am also battling the rattles in the cargo area.
Old Jan 9, 2008 | 11:29 PM
MBTeen's Avatar
I'm having the same problem... Odd timing especially, as I just took it in to the shop and they surmised that it was a cut in the rear window antenna and quoted me $1,500 for the fix! I'll definitely try the fuse asap.
Old Jan 10, 2008 | 09:15 AM
  #9
I'm not convinced the problem was properly diagnosed by Mercedes when I had them check it. They told me that I would have to replace the Combar and the was a possibility of them breaking the rear window. Also, they indicated they would have to call in someone to remove the headliner as well as the window to replace the Combar.
If they were not able to get to the Combar without removing the headliner how were they able to determine that is what causes the problem?
If they replace the combar and the problem isn't resolved do they continue looking for a possible solution at over $100 per hour.
I would be interested in how your problem is addressed.
Thank you.
Old Jan 29, 2008 | 09:35 PM
  #10
I had a professional install an after market antenna that attaches to the window soI now have reception on the radio and didn't have to drill any holes in the car or spend over a thousand dollars.
