Interior Temp Guage - Flaky Readout
Old Jan 1, 2005 | 09:21 PM
LoveMyE420's Avatar
Default Interior Temp Guage - Flaky Readout
The digital temperature guage on my 94 E420's dash has always displayed what appears to be an inaccurate temperature -- always +37 F when I fire her up most mornings, which can't be true (I live in temperate California), and seems to hover around this number as the day goes on. On rather "cold" mornings (by CA standards), it may read as +28 F or such as I drive along. On "hot" days when she's been sitting in the sun, the gauge will display +75 F or +80 F, and then drop back to +60 F or so as I drive along and the AC kicks in.
About two weeks ago, the display would flicker when I fired her up in the mornings, then just fade out, then perhaps come back. It did this for a few days, then returned to its "normal" behavior and has not repeated the flickering since.
I checked the owners manual and it says that the sensor for the internal temperature guage is under the front bumper...could something have been clogging it causing the flickering? Does this sensor simply wear out over time or need resetting?
Any ideas on these types of behavior?
Thanks!
Old Jan 2, 2005 | 04:07 AM
sleepwalker's Avatar
Default RE: Interior Temp Guage - Flaky Readout
that temperature sensor is just a resistor which changes the value according to the temperature.
maybe what you need is to check it's resistance compared to the actual value that it is suppose to show.
if you can do it, i can send you the comparison table.
subseafb
Aug 13, 2007 06:50 PM
roaster
Nov 9, 2006 10:30 AM
miishmiish
Jul 9, 2006 03:13 PM
pbassett
Sep 23, 2004 12:36 AM
rr_havuz
Mar 11, 2004 07:55 AM
