Help Please
Old Dec 18, 2006 | 06:38 PM
randy78045's Avatar
Default Help Please
I was recently midway into a 3 hour trip when I noticed that my LCD clock/shift indicator was not working. Shortly after that I noticed that my a/c was not cooling. I dont know if this was coincidence that both stopped about the same time or if these two issues are related. Since this the clock/shift indicator has come on occasionally only to go out again, or fade into existance then out. The a/c doent cool at all anymore. Anyone have any ideas what may be the problem? The car is a 2001 E320. Thanks...
Old Dec 18, 2006 | 07:48 PM
Battlecat714's Avatar
Default RE: Help Please
checked fuses?
Old Dec 18, 2006 | 08:49 PM
sleepwalker's Avatar
say goodbye to your instrument cluster.
Old Dec 19, 2006 | 03:57 AM
snanceki's Avatar
The pack has stopped working due to poor internal connection.
Well known and documented problem.
Change pack is the usual action to resolve but expensive and if you buy a pack off a wreck you run into all sorts of problems with coding.
You can get the existing pack repaired which is also very expensive but avoids the coding problem (you still use the same pack) but are left with a car with no pack for a week or so.
However if you are a competent DIY'er the actual fault is quite easy to repair but please don't ask for a step by step how to do it. If you don't feel competent and need to ask for such a guide this solution isn't for you.
Remove pack (special tool from eBay). Disassemble the pack. Make good the ribbon connection from the PCB to the readout display. Quality of connection is ****.
Its as simple as that!
Stuart
Old Dec 19, 2006 | 01:31 PM
randy78045's Avatar
Is the "pack" the same as the instrument cluster?
Old Dec 19, 2006 | 01:36 PM
snanceki's Avatar
Yes.
Stuart
Old Dec 19, 2006 | 04:28 PM
randy78045's Avatar
I'll probably have to have somebody fix it... when you say expensive, do you think more than $500
Old Dec 20, 2006 | 03:50 AM
snanceki's Avatar
Ring the dealer and ask. I think it may cost more than 500USD. I do not know what rates are charged where you live.
Stuart
MARIODRIVE
Nov 23, 2008 05:39 PM
lubee84
Feb 16, 2008 10:29 AM
sql123
Dec 1, 2007 12:11 AM
ezeneli
Apr 8, 2005 03:05 AM
siddiqui2000
Feb 16, 2005 01:16 AM
