coolant change E320 2000
Old Jul 10, 2006 | 11:00 PM
chiro's Avatar
Default coolant change E320 2000
Am going to change my coolant and have not done it before. Need I only remove the lower hose and let it drain?
Brad
Old Jul 10, 2006 | 11:03 PM
sleepwalker's Avatar
Default RE: coolant change E320 2000
there's a drain plug on the radiator.
loosen it and keep the reservoir cap open.
Old Jul 11, 2006 | 03:52 AM
chiro's Avatar
Thanks for your reply . I am assuming that this will drain both block and radiator. Then I just replenish with MB coolant at 50/50 and no need to flush..?
Brad
Old Jul 11, 2006 | 04:10 AM
it won't drain the block, but it doesn't really matter for you have to flush it once.
fill with pure water, run engine till 80 degrees, drain and refill with 30-50% coolant mix.
Old Jun 16, 2009 | 02:55 PM
Scuddog's Avatar
Default Dangerous?
Fellas, I am about to do the radiator drain myself. The question that I have concerns the fill with pure water... won't that boil when brought to 80 degrees Celcius? After it hits that temp and the car is turned off.... I should wait an hour or so to drain the water... right? After that I can fill with the MB coolant at a 50/50 distilled water mix ratio.
Does the pure water cycle really do a flush job? Would a store bought flush like Prestone's Super Flush be beneficial or harmful? Thanks in advance.
PelicanParts.com
Sep 20, 2013 06:55 PM
JERSEYSURFER
Oct 2, 2008 01:03 PM
reza1u
Sep 13, 2008 06:43 PM
allan l
May 24, 2006 08:45 AM
inssane3gt
Jan 15, 2006 06:07 PM
