Sleepwalker, DIY coolant change question
Old Jan 12, 2006 | 05:57 AM
inssane3gt's Avatar
Default Sleepwalker, DIY coolant change question
2000 E320
I was about to drain and refill the coolant but I ran into a problem before I even started.
How do I access the radiator cap? Do I have an air bleed bolt?
I would really appreciate a view of the pages in the repair manual that cover this service.
Old Jan 12, 2006 | 11:57 PM
sleepwalker's Avatar
Default RE: Sleepwalker, DIY coolant change question
no need to bleed for air because it is self bleeding.
just drain the coolant. do not overfill the reservoir, you need to leave some space for expansion.
[IMG]local://upfiles/1/CD57D9764CF843CEBD7671E31806C060.jpg[/IMG]
Old Jan 13, 2006 | 12:06 AM
inssane3gt's Avatar
Thanks for your reply.
So there is no cap on the radiator? I refill the system through the reservoir?
I have 2 crankcase plugs right?
Old Jan 13, 2006 | 12:12 AM
yes, no radiator cap...just that expansion tank (reservoir) cap.
2 crankcase plugs. you may drain from there too by using 17mm socket or wrench.
remember to turn on your a/c heater full when refilling it to get rid of air pocket inside.
Old Jan 13, 2006 | 12:49 AM
inssane3gt's Avatar
So I'll refill the coolant, leave the reservoir cap off, start the engine, and turn the heater on full? Then do I just let the engine idle for about 10 minutes? Then shut the engine off, top of the coolant and recap the reservoir?
Old Jan 13, 2006 | 12:55 AM
yes.
Old Jan 13, 2006 | 01:03 AM
inssane3gt's Avatar
Thanks, you're the man.
Old Jan 13, 2006 | 04:25 PM
qghauri's Avatar
Can i have a picture of my 1995 E320, automatic, showing the change of coolant as mentioned in the above tread. I want to change the coolant of my car myself.
Regards
Old Jan 13, 2006 | 07:53 PM
  #9
inssane3gt's Avatar
Sleepwalker or anyone who can answer my question,
Where are the two crankcase bolts? I was underneath the vehicle with a flashlight and I don't see them. I did find two bolts on the side of the tranny, but they were bigger than 17mm.
Can you please describe where they are? Thank you
Old Jan 13, 2006 | 08:27 PM
  #10
inssane3gt's Avatar
Oh and that picture is from a 202, I have a 210 engine. Thanks
