99 E320 won't start
Old Aug 4, 2009 | 05:17 PM
boman49's Avatar
Angry 99 E320 won't start
Started fine this a.m. No prior problems then ten minutes later won't even crank. I checked all the fuses & then replaced the battery with a brand new one. Still nothing when I turn the key. HELP!
Boman49
Old Aug 4, 2009 | 06:24 PM
chassis221's Avatar
try a differnt key if you have one 1st. also maybe the flywheel needs lubricated. the starter becomes dry on they flywheel and can cause this, but usually it will squeek for a second, but then will start. another thing to check is if youve got a bad pulley bearing and its not allowing the belt to spin freely. thus straining the engine and starter. are you sure your fully in Park? turn the key to position 2 and put it in gear and then back into Park and see if that helps.
Old Aug 4, 2009 | 08:09 PM
boman49's Avatar
Default Keys etc
I tried both keys. Put the key in position 2 & shifted in & out of gear & back to park. No good. I even tried it in neutral. There has been no squeeking or squealing or other pre problem signs. What else should I try?
Old Aug 4, 2009 | 08:56 PM
phillip jones's Avatar
try moving the gear stick back and forward few times fast!!!!! if its not a starter motor fault then maybe there is aprob in the inhibator switch on the gear selector
Goldengirl1
Nov 8, 2012 07:28 PM
davidmlee
Dec 21, 2011 03:44 PM
doobs
Dec 21, 2008 09:58 AM
mhphoto
Jul 16, 2007 11:51 PM
moonbike
Oct 6, 2004 10:22 PM
