to stagger or not to stagger?
Old Mar 13, 2007 | 01:14 PM
clk4steve's Avatar
Default to stagger or not to stagger?
I have a 2003 CLK 500 aI have bought a set of 19" x 8.5" rims.I am getting mixed information on the tire sizes that should be mounted. I have been told to stagger them by one shop andnot by another. I can still return 2 if I have to in order to stagger them. Is there any reason that they should or shouldn't be staggered?
Thanks in advance!
Old Mar 13, 2007 | 11:35 PM
chassis221's Avatar
Default RE: to stagger or not to stagger?
from the factory the car has staggerd wheels and tires. it should tell you on the driver side door jam.
Old Mar 14, 2007 | 04:43 AM
BlueSilver's Avatar
Well, they will tell you if the tires are the same, you can "rotate them".
Personally, I check my tires often enough to correct any weird tire-wear", and correct any alignment or camber adjustments, so they wear evenly without rotation. And I went with the Michelline Pilote Sporte A/S's (treadwear 400) which are holding up great.So my advice would be to get what you want, but you know that any tire with less than 320 treadwear is going to wear quickly.
blue
Old Mar 15, 2007 | 01:50 AM
wildoutfilms's Avatar
I just put rims and tires on my 2000 clk 18x5 225/40/18 for the front and 19x5 255/35/18 for the back [align=center][/align]
Old Mar 15, 2007 | 10:12 PM
BlueSilver's Avatar
Wildoutfilms!
What color is your CLK?
That is the color I should have bought!
Blue
Old Mar 16, 2007 | 06:37 AM
chixdiggit's Avatar
No reason why you shouldn't stagger them. Wider tires in the rear will give you better traction and handling.
If you look at the wheel sizes on the factory tires, the rear wheel is actually taller than the front by one size. ie: depending on the size of your rims, if the front is 35 the rear will be 40. I do not believe you can rotate them anyways.
Old Mar 27, 2007 | 09:04 PM
JOE55's Avatar
Always Staggered
Old Mar 29, 2007 | 09:27 PM
renzkitty's Avatar
staggered fitment will give your car a better traction and handling. i have an 04 500 and my front tire is 19x8.5 235/45 and rear 19x9.5 235/65. it does not rub the fenders and riding smoothly.
Old Mar 30, 2007 | 03:56 PM
  #9
CLK500KID's Avatar
I got a 2004 clk 500 and i use 235/30/19 for the front and 285/30/19 in the back. the back use to rub until i got a new set and the dunlops didnt the bridgestones did and they get burned off fast, i use then for about 15000 and i need a new set, in the rear already but if u want to be on the safe side then go ahead and use 275/30/19 in the rear cause u will def feel the difference and the esp wont play around as much if u get a non stagg set
good luck
Old Apr 11, 2007 | 02:09 PM
  #10
clk4steve's Avatar
Thank you for the replies, it has been very helpful!!
gharnden
Mar 7, 2014 02:09 AM
Paul Dalton
Feb 7, 2012 02:37 PM
Hi Speed Motors
Aug 7, 2009 03:22 PM
laser_doc
Nov 4, 2008 05:39 PM
chicagoc320wagon
Jul 29, 2008 10:13 AM
