Help with cabro roof - it wont go down :(
Old Nov 25, 2007 | 10:51 AM
mrmambo's Avatar
Default Help with cabro roof - it wont go down :(
I have just collected a 2004 clk 320 cabrio.
I am trying to put the roof down - but a message is showing on the panel "close boot / ski"
I have checked the boot, and all appears to be fine !!
what am i doing wrong -
please help
Old Nov 25, 2007 | 10:55 AM
chassis221's Avatar
Default RE: Help with cabro roof - it wont go down :(
YOU MUST GRAB THE HANDLE WITH THE PALM OF YOUR HAND FACING UP, THEN PULL DOWN TOWARD THE BACK OF THE CAR, THAT SHOULD DO IT. UNLESS YOU HAVE A BAD SWITCH.
Old Nov 25, 2007 | 10:58 AM
mrmambo's Avatar
its a button
Old Nov 25, 2007 | 11:13 AM
mrmambo's Avatar
so what do i do ??
it worked in the garage
Old Nov 25, 2007 | 11:31 AM
chassis221's Avatar
not sure what to tell you, if it says boot/ ski thats the thing in the trunk that you need to pull down......??? not sure its hard to explain or describe without pictures. you say that it worked for you earlier?? i would try to pull down the partition in the trunk again. make sure its fully engauged.
Old Nov 25, 2007 | 11:45 AM
mrmambo's Avatar
ok - where is the partion in the trunk , whats it look like ?
Old Nov 25, 2007 | 11:48 AM
mrmambo's Avatar
ah great found it many thanks respect to you
Old Nov 25, 2007 | 11:55 AM
chassis221's Avatar
YOUR VERY WELCOME!!!
MARIODRIVE
Nov 21, 2008 05:20 PM
cooper1977
May 17, 2008 10:03 PM
iant61
May 27, 2007 03:19 AM
ahmedny
Jun 14, 2006 02:42 AM
josh740
Apr 10, 2006 06:59 PM
