Help with cabro roof - it wont go down :(
I have just collected a 2004 clk 320 cabrio.
I am trying to put the roof down - but a message is showing on the panel "close boot / ski" I have checked the boot, and all appears to be fine !! what am i doing wrong - please help |
RE: Help with cabro roof - it wont go down :(
YOU MUST GRAB THE HANDLE WITH THE PALM OF YOUR HAND FACING UP, THEN PULL DOWN TOWARD THE BACK OF THE CAR, THAT SHOULD DO IT. UNLESS YOU HAVE A BAD SWITCH.
its a button
so what do i do ??
it worked in the garage |
not sure what to tell you, if it says boot/ ski thats the thing in the trunk that you need to pull down......??? not sure its hard to explain or describe without pictures. you say that it worked for you earlier?? i would try to pull down the partition in the trunk again. make sure its fully engauged.
ok - where is the partion in the trunk , whats it look like ?
ah great found it many thanks respect to you
YOUR VERY WELCOME!!!
