CLK 320 Windshield Washer not working
Old Dec 3, 2018 | 04:55 PM
MBZ_CALIFORNIA's Avatar
Default CLK 320 Windshield Washer not working
Hi everyone,
I have a 2001 CLK320 and my windshield washer dos not work.
-Wiper works fine.
-Pump works fine because it sprays water to the headlights.
Any ideas where I should look to find out the problems?
Thx,
Old Dec 3, 2018 | 06:12 PM
PelicanParts.com's Avatar
Hello and welcome to the forum! Which part is exactly not working? If it's the nozzle, it could be clogged.
Old Dec 17, 2018 | 05:39 PM
Mac Romedia's Avatar
Thanks for your reply/follow up question PelicaParts.
I was not able to login with my previous user account so I created a new one.
Anyhow, the problem is when I press the end of the stock inward to get the washer to work, I do not hear/see the pump working. And do not see water spraying to the windshield.
I do see the pump spraying water to the headlight when I press the headlight washer. Both windshield and headlight user the same tank to spray water and there is one pump in the tank.
I checked the fuses and they seem to be working OK. Not sure if windshield and headlights have different fuses.
Is is possible that the windshield switch is not working? Is it a lot of work to take the switch out and check test it?
Thanks for all your help in advance.
Old Dec 18, 2018 | 04:11 PM
No problem, happy to help out! Take a look at the links below, perhaps it'll help you troubleshoot. Please let us know if you have any other questions or if we can assist with any future part needs.
https://www.benzworld.org/forums/c20...t-working.html
You are being redirected...
Old Jan 2, 2019 | 07:55 PM
This guy figured it out. It should work for all other BENZ models not just CLK.
tlee
Oct 7, 2011 07:07 PM
bmaxey
Feb 27, 2009 06:45 PM
96SL500
Sep 7, 2008 03:39 PM
stevec
Jul 28, 2007 04:21 AM
honeybee
Mar 14, 2004 07:10 PM
