windshield washer pump
Old Mar 4, 2004 | 02:43 PM
honeybee's Avatar
Default windshield washer pump
Hi,</P>
Cansomeone please tell me if my 94 C280 has only one water pump for windshield washer or two (one on each side)? The nozzle on the passenger side is more like weeping rather than projecting a strong jet of washer when I press on the control. </P>
Can it just be the nozzle getting stuck or a sign of pump failure?</P>
Much appreciate it.</P>
KC</P>
Old Mar 12, 2004 | 07:57 AM
rob04's Avatar
My '94 C180 has only one pump, and I'd guess your C280 is the same. More than likely that some polish or other deposit has got onto the holes of the jets on one side. I usually strip a small piece of automotive wire and separate one of the copper strands which is then thin enough to poke down the hole and clean it out. Be careful not to swivel the jet, otherwise you'll havewater go over the roof etc. Sometimes helps to have someone else press the washer switch while you adjust and clean the jets.</P>
Cheers.</P>
Old Mar 13, 2004 | 02:07 AM
honeybee's Avatar
Thanks Rob. Will give that a try. Kind of hard to find a thin enough wire! By the way, I didn't know the nozzle can be moved. The strangest part is, if I press for washer once, the jet comes up a bit stronger (still kind of pathetic) then subsequent tries will be like "having a bladder stone"!<IMG src=smileys/smiley5.gif border="0"></P>
Thanks again.</P>
KC</P>
Old Mar 14, 2004 | 07:10 PM
rob04's Avatar
Sounds like there's a "loose" piece of dirt in the pipe, not large enough to come through the nozzle.</P>
First press pushes out some water, but then the dirt blocks the hole and very little can come out. Might be worth while removing the pipe from the rear of the nozzle and operating the pump to clear any debris.</P>
Cheers.</P>
David6FL
Jul 30, 2010 06:52 AM
CLK320-Blue
May 22, 2009 03:22 PM
skatyal
Mar 15, 2007 03:12 PM
fay3131
May 27, 2006 12:37 AM
honeybee
Jan 18, 2004 02:16 PM
